pyrorider avatar image
pyrorider asked
Multiplus II is not compensating its own phase
Hi, after having the Multiplus 48/5000 in charger only for 2 weeks I now switched it bacj to "ON" and tried doing a discharge test, now I noticed that the multiplus which is set to compensate all 3 phases to -10W Via an ABB RS485 energy meter is only compensating for L2 and L3 and completly ignoring L1. The system worked fine before, I didnt do any updates so I can't really explain why the Multi does what it does
Edit: My batteries BMS is not connected to the victron, the Batterie capacity etc is managed by a smartshunt directly at the batterys negative terminal
Multiplus-II
