oblio avatar image
oblio asked
Help with Re-engineering my battery system
My sailboat currently has 4 batteries in 2 banks of type 27 batteries. The system is running 12v. The boat has a battery switch "1 both 2 and off". It currently doesn't have a separate starter battery, but I want to install one of the type27 batteries as the starter battery.
I have a new running mttp 100/50 and two 330w panels charging 3 parallel 4D AGM batteries that are mounted and charging, but not connected to the system that will be my house batteries.
I'm looking for a schematic that I can use to properly install the system. New battery switches and isolator with a battery monitor.
Is there a schematic available to follow?
modifications
Mark avatar image
Mark answered ·
Things can get complicated quite quickly and I would recommend that you engage the help of a professional installer.
But there are a number of very comprehensive electrical schematics on the Victron website in the download > system schematics area:
https://www.victronenergy.com.au/support-and-downloads/systems
This example might be relavent for you as it includes a starter battery and alternator in the system, but there are many others;
https://www.victronenergy.com.au/upload/documents/VE-Bus-BMS-example-with-3KW-12V-MultiPlus-230-Volt-revision-B.pdf
Experiments, Modifications and Adaptions. Mods (Modifications) can be made to Victron Software by the Community. Please use the modifications space for enthusiasts who want to push what is possible, without official Victron Support.
