palmern avatar image
palmern asked
EasySolar II indicates 46.5% battery but Solar charger indicates 78%
looking at the display this morning the Easy Solar was showing batteries at 46.5% -connecting a Generator indicated only 50W of charge load. connecting to the Solar Charger via blue tooth shows the batteries at 78%.
which is correct ? how do I get display to show correct level ?
Note - this is a new install so its likely a setting but which ?
Regards
Nick
MPPT Controllers
6 comments
What is in the system? is.this a model of EasySolar with built in GX?
Usually the battery state comes from a smart shunt or the BMS in compatible lithium batteries. Also if it's winter where you are the batteries may limit charge due to temperature and other reasons
palmern avatar image palmern commented ·
So to add a little more info as requested by kevgermany
Yes it has built in GX Firmware V3.01, Battery config is 180Ah 48V AGM.
After a system restart battery level is now 100%- This I can understand as it does not know now the exact battery state anymore. How do I get a correct result of battery level easily ? there are no other DC loads connected to battery bank.
Alexandra avatar image Alexandra ♦ palmern commented ·
If there is no shunt you cant trust either.
Not sure what you connected to but a solar charger does not give SOC?
How is the system programmed? Was any of the firmware updated?
kevgermany avatar image kevgermany ♦♦ palmern commented ·
Where are you reading SOC? What is the source of the reading?
100% after restart sounds very much like a BMV or smart shunt.
palmern avatar image palmern kevgermany ♦♦ commented ·
Too add as best I can the system consists of a GX device
Smart solar charger MPPT 250/70
An inverter / charger
And a gateway
The front display is what is indicating battery charge level but logging into the solar charger gives a different figure
Also looking at it online gives the same charge figure
Nick
As @Alexandra said, any SOC figures are approximate, unless there's a shunt based battery measurement. This can be a BMV, or smart shunt. Some lithium battery BMS will also give accurate SOC values to the GX, but those which work off battery voltage generally don't.
zimbel avatar image
zimbel answered ·
I had a similar issue lately with my EasySolar 2 and a self built Battery storage.
After a few months the BMS said that the SOC is 46,2% while simultaneously running into undervoltage protection. I had changed the "charging strategy" to 15%-50% (start using the battery again when 50% is reached) and it seemed that the BMS lost track of the correct SOC. I had to fully charge the battery to 100% and now it's working again (and i hope with more or less correct SOC)
I shall give that a try and advise outcome
