I have two sets of solarpanels. One with 360 Watts 12volt. The second 500 Watts 18 volt. I don’t want to mix them with different kind of serial connections. Is there a regulator with two inputs?
No not in the Victron MPPT solar charge controller selection.
https://www.victronenergy.com/solar-charge-controllers
You can use 2 separate MPPT charge controllers (one for each solar panel/array), but your probably just best off using a single MPPT and matching/compatible solar panels.
8 People are following this question.
