silver02 avatar image
silver02 asked
Dynamic ESS Functionality
since I did not find an answer to my question by using the search funktion, here a simple question regarding Dynamic ESS:
Is it possible to use the Dynamic ESS for the following functions:
- Charge the storage battery from the grid (Tibber) if the price is lower than xx ct/kWh?
- Discharge the storage battery only if the price is higher than yy ct/kWh depending on the consumption?
- Plus charging the storage battery with the excess from PV depending on the configuration of my wallbox for charging our EV?
Wallbox: OpenWB
Inverter: SMA, PV 10 kWp
planned: Victron Multiplus-II 1-ph 5kW, Cerbo GX, 10 kWh storage battery.
Thanks for answering in advance.
Best regards, Andreas
dynamic ess
