Trying to find out information on how to connect my 2 x 48V 100AH BATTERY – 8D to my victron system to communicate the built in heat temperature. I have a 48v Multi plus II and Cerbo gx.
What Victron system do you have? Please list all parts exactly.
At the moment we have no solar just the multi plus II and cerbo gx with 2 x Volthium self heating 48v 100 ah batteries
Full system until spring when we see the sun again. We also have a Honda EU3000is generator connected with auto start.
Contact Volthium they will get you a little black box (Volthium Communication Hub) to convert their BMS Canbus over to BMS.Can using the communication ports on your batteries. The batteries will automatically show up on your Cerbo with all data (voltage, current, SoC, temperature, capacity, etc). It will also allow the BMS to talk with the Victron equipment.
Alternatively, if you use the Multi temperature sensor, it will give the GX device a battery temp reading that should be shared toward the other chargiing equipment (such as your future solar controller).
44 People are following this question.
