stonihiha avatar image
stonihiha asked
MultiPlus-II 48/3000/35-32 do not load battery with maximum ampere
Hi Comunity,
I use an MultiPlus-II 48/3000/35-32 with a AC- an DC coupled system an EM540 an setpoint 40W.
At the moment I have a lot of AC PV Power (1700W) and less DC Power (150W).
I send back more then 1000W to grid and the Multiplus charger only charge with round about 16A. Like I understand the datasheet it should load up to 32A. How can I find out why the charging current is reduced.
Too specials are in my system: I use an BMS that is not supported by Victron Energy, so I use Node-Red to read the SOC from BMS and send it to Victron via ModBus
Regards Jürgen
Multiplus-IIess effizienz
Alex Pescaru avatar image
Alex Pescaru answered ·
What is the SOC value?
Because, maybe the BMS is telling to not charge with more than 16A, if the SOC is towards the end 100%, absorption for example.
stonihiha answered ·
In this case tle SOC is less then 100%, currently 30%.
The only value I route from BMS to Cerbo is SOC.
pim57 avatar image
pim57 answered ·
Do you have DVCC turned on?
Because this feature can reduce the charge current.
Yes, but the limit charge current is off.
I have to use it, because the battery has only 15S, not 16S, so I have to reduce the maximum charging voltage to 54V.
