hallo
I have a setup where my quattro has connected a generator on AC2 IN, I would like it to only charge the batteries and let the inverter pull the load
how to set that in config???
best
hallo
best
That's not possible, you can't use AC IN (1 or 2) to charge and use the inverter at the same time.
Charging and inverting uses the same electronics.
80 People are following this question.
