Does something like this exist from Victron, I wish to use the large capacity Lithium batteries to trickle charge and maintain the Starter Lead Acid Battery.
Not a trickle charger.
But smaller chargers for 12v, yes
Look up ip65 chargers, they come in alot of sizes. 1A upwards. Has neat accessories.
Then there is the ip22 blue smart.
BTW it is the one in your attached diagram.
Look at the Orion range. These are DC:DC chargers/converters.
If you check the datasheet from this link, all the models are listed. You're going to need a 12/12 for 12V in, 12V out. The third figure is the max current.
https://www.victronenergy.com/dc-dc-converters/orion-tr-smart-non-isolated
Thanks kevgermany, looks like I’m going to fit 2 orion’s to charge both ways.
1) the soon to be released Orion XS 12/12 - 50A set to lithium charge algorithm to charge the house battery from the alternator when driving and a
2) Orion TR Smart 12/12 - 18A set to lead acid charge algorithm to maintenance charge the starter battery when the car is stored for a few months
This way the lead acid stays at 100% as lead acid needs to stay full to protect its life span, and it does not matter if the lithium house battery discharges a bit as only the cycles affect the lithium.
Thanks all
Let’s hope I don’t make smoke.
42 People are following this question.
