sandman avatar image
sandman asked
Is 5 panels to much?
Hi I have a 150/45 with four 170W panels with max P and Short Circuit A of 9.5 Amps. They are I assume all in parallel, plugged into a 3 port box (2 with a parallel pigtai)l on the roof of my RV. The openV is 23.8V know the efficiency of these panel are no where near 100% which brings on the inquiry.
Would I be pushing it if I add one more 170W PV? Thanks.
John
Solar Panel
Alexandra avatar image
Alexandra answered ·
@Sandman
Input short circuit limit on the 150/45 is 45A.
5x 9.5A is over the limit at 47.5v. so would definitely be a no.
Even if they were series parallel you can't add one more to a string you would need to add two to be even.
