csimmo avatar image
csimmo asked
Victor monitor reading 100%
I have two 240 solar king batteries and 4 x 185 what solar panels and 170 amp solar regulator one 300 W pro inverter. I’ve run my air conditioner for three hours and system shuts down still reading 100% but drops to 11 V any ideas how to fix the problem thanks
BMV Battery Monitor
kevgermany avatar image
kevgermany answered ·
Which Victron monitor do you have?
Most of these problems are caused by incorrect wiring, allowing current to bypass the shunt.
The shunt should be the only connection to the battery negative. Every other negative must go to the load side of the shunt.
