pal-80 avatar image
pal-80 asked
Home Assistant integration in Node-RED
I´m try to install node-red-contrib-home-assistant-websocket from pallete. The installation is not possible because the integration requires version 3.1.1 of Node-RED and the version available in Venus OS is 3.0.2, do you know if there is some way to install this integration on Node-RED?
Node-RED
Alexandra avatar image
Alexandra answered ·
@Pal_80
Update the Venus version. The newer versions have better pallet options.
I have not tried home assistant integration though. I just noticed the improvements in the things have been playing with.
Leon Backbier avatar image
Leon Backbier answered ·
Would be great to have indeed, so we can access all registers and set helpers and sensors in HA
