chrisco avatar image
chrisco asked
Shutdown for 3 seconds if grid fails South Africa
Good day you all. Im from south africa. Have a multiplus 12/1200/50-16 and want to ask a question. Loadshedding times when the grid fails the inverter shutoff for 3 seconds and then go back on and stay on normally but do not always shutdown. Sometimes the inverter switch to inverter mode very quickly without intteruption. Is every 3rd or 4th loadshedding when it shutdown for 3 seconds and then back on. Only when grid fail. It is not brown out because I put it self off by the circuit breaker to test. And not overload because we do not use alot on the inverter.
Do have a Lithium Battery built in BMS 188AH
Nominal Capacity (Ah)
188
Total Energy Capacity (kWh)
2.400
Energy, 80% DoD (kWh)
1.920
Standard Charge Current (A)
70
Max Charge Current (A)
125
Charge V bulk absorption (VDC)
14.1
Charge V float (VDC)
14
Recommended constant discharge (A)
100
Max. Discharge Current (A)
125
Discharge Cut-off Voltage
12V@0.005C
BMS (Charge/Discharge)
125A/125A
Op.Temp Charge/Discharge
0° to 45°C / 0° to 55°C
Protection
125A SP Circuit breaker
Minimal Cycle Life
4000 cycles @0.5C 80% DoD
I hope You guys can help me with the problem.
Multiplus-II
7 comments
Can the battery take the sudden inrush / surge when going off-grid?
I have also seen sometimes when the system is caught (since it synchronises to grid) right where the sine wave passes through zero there can be a hiccup in switching over.
Do you have the SA grid code selected?
chrisco avatar image chrisco Alexandra ♦ commented ·
yes I think so, because sometimes I have like 40 DC Amps load then the inverter switch quickly over to inverter mode without interruption and sometimes inverter shutoff for 3 seconds and then turn back on by itself and stays on
There is no option for South Africa grid and I have the newest firmware
Alexandra avatar image Alexandra ♦ chrisco commented ·
Do you have ups marked as an option then? What are the cut off voltages?
Cut off voltage is on 10V and yes have the UPS Funtion on. And the AC Input low is 195V
Dont know what that means? I did take the photo a month ago or so
Will a Auto Transfer Switch help with this problem?
chrisco answered ·
