My Multiplus 2 3000VA overheats every 30 minutes while charging from 230V, ~1500W. It then stops charging for couple of minutes and continues charging normally. Is this harmful or normal operation, regarding longevity?
Sounds like lack of air flow and it's shutting down to protect itself. Are the air vents obstructed? Are the fans running? Is it in a confined space with restricted air flow?
I can lower the charge power if necessary, just want to know if overheating is harmful.
The life and performance of any electrical system is based on temps of 25C. The electronics will protect themselves but it is unlikely they will last as long as a cooler system. Batteries in particular will degrade faster in warm temps.
Ultimately it will survive its warranty, as you will get a replacement regardless. Beyond that, it’s your problem.
101 People are following this question.
