Hello - we have a MultiPlus-II 48/5000/70-48 and have tuned down the charger settings (20A) to allow for a smaller generator to operate without overloading (Honda E22i). Will this impact the amperage on the MPPT as well or not? hopefully not.
Your settings here are only affecting the MultiPlus, not any other components in the system.
Personally I would turn down the AC Input Current Limit rather than the charger settings, but this way might work as well.
@James09 It wont affect the MPPT. If you did at a later date want a global charge limit, you can do that within DVCC settings.
The settings noted in your post are for the MPII only.
46 People are following this question.
