Are there some plans for a microinverter concept.
Now for mixed shaded panels the only option are microinverters. Is victron working on something like that ?
I do not think, that Victron will do it since there are already manufacturers, e.G. Hoymill, which do it already with a very nice perfornance.
These are AC micro inverters. It would be nice to have something as a DC micro inverter.
Mppts are already manufactured in small sizes. 75/15 & 75/10. And they run loads from them.
Other manufacturers make them smaller. What would you want it for?
I was thinking to add them under the PV panel just like a micro inverter but just DC.
I have a string of 10 panels that get some shade from the neighbours house that is moving over the panels. This string is DC coupled to my battery. So with some kind of DC micro inverter I could get more out of these panels.
Only oroblem is, that the 75/15 cost 140€ and the 100/20 180€ which is a little bit expensive compared to the Hoymill
How big are your panels? (Watt and Voc)
What is your System Voltage?Yes there are such things called "optimizers" but Victron does not make them.
98 People are following this question.
