So my 1. gen multiplus nebver goes from float to bulk by itself. I have to force it by turning it off and on. It will literaly stay in float all until mye lifep04 batteries are all drained.
I hope someone can shed some light on this situation.
A couple of notes.
Update the firmware if you can on the inverter. 1st gen can update depending on what chip it has. What it's the chip number?
Second on the new firmware there is a check box for lithium.
What is the input current limit you have on the system?
Do you have solar? Are you running the ESS assistant?
I have been told by the Norwegian Victron importer that I should not attempt to update firmware as it will give very little added functionality, and a substantial risk of bricking the unit.
My unit does not support assistants.
41 People are following this question.
