mose avatar image
mose asked
AC Load Psum on MQTT?
Where can I find the power sum value of the AC loads on MQTT? I'm not able to find it on there. The value I mean is 378W in the attached picture.
For L1-L3 I use
N/+/system/0/Ac/Consumption/L1/Power
N/+/system/0/Ac/Consumption/L2/Power
they seem correct.
At first I thought
N/+/vebus/257/Ac/Out/P
could be the right value, but only when no power comes from the inverter and everything from the battery. Otherwise it gives the difference of value on AC-Out (makes sense, but is not what I need).
Of course I could sum up L1-L3 but it would astonish me if the value that gets display on the screen is not on dbus, resp. on MQTT...?
CCGX Color Control
ben avatar image
ben answered ·
Pretty sure it's not on DBus (and therefore not on MQTT). I believe you'll have to add them up.
