pc15 avatar image
pc15 asked
Winter Error on Panels
We have (12) 370W, 34V, 10.87A solar panels / 250 MPPT charge controller - currently in 2 parallel series of 6 panels. We have been running into a "Fault" on our panels when the winter weather gets below 10 degrees and it is super clear sunny day - when the sun hits the panels, it will "Fault"
Is this because the voltage will jump over what the system can handle because of the cold weather?
Has anyone experienced this before? Any solutions? Should it be rewired to 4 series of 3?
Thank you!
Solar Panel
mjs500 avatar image
mjs500 answered ·
do you no full spec for your panels i.e. voc - isc vmp and imp ?
from your small spec
am I right in saying CS3L-370 panels
Voc 40.8v --- Isc 11.54 A ---- vmp 34.1V ---- imp10.86 A
currently in 2 parallel series of 6 panels. do you mean 6 panel in series x 2 strings so 12 panels in total ? if so
PV max. voltage @ min. temperature 274.8 V
and your mppt max pv input voltage is 250 v
klim8skeptic avatar image
klim8skeptic answered ·
@pc15 Yeah, the cooler the panels are, the higher the panels voltage. At -10c your panels Voc is likely to be 10% higher than the spec sheet stc figures (stc = 25c).
It would be a good idea to rewire your array as 4 series x 3 parallel before the smoke comes out of your mppt.
Please use the Victron mppt calculator. to ensure the mppt never sees over 250v, and the array Isc is below the Isc mppt's rating.
@pc15
By good idea, he means do it now!
mjs500 avatar image
mjs500 answered ·
PV input voltage
PV min. voltage @ max. temperature 164.1 V
your 6 panel in series x 2 parallel so 12 panels in total = PV
PV input voltage
PV max. voltage @ min. temperature 183.2 V
PV min. voltage @ max. temperature 108.3 V
your 4 panels in series x 3 parallel 12 panels in total = PV
Lars Filusch avatar image
Lars Filusch answered ·
this is because the voltage coefficient for solar panels is always negative.
Take a look at the solar panel data sheet.
That means the voltage rise on lower temperature... always.
I always calculate Uvoc + 5% for lower temperature.
