gexle avatar image
gexle asked
Venus OS Temperature Service -> Rikkert-RS
Hello Kevin
Ask:
I installed Setuphelper, RpiGiposetup from you and also the script RPITemperature
I would like to install the Venus OS Temperature Service -> Rikkert-RS.
The problem is that when I want to install it againRaspberry Pi CPU temperature installed.
Can't I just install Venus OS Temperature Service from Rikkert-RS?
Enabled features in this setup:
1-Wire Support (Temperatures) Data Port GPIO 26 on RPi
And then just switch it to GPIO 4??
As I said, I already installed RpiGiposetup.
Is this a Problem??
Still question
If Venus OS Temperature Service -> Rikkert-RS is installed, I can also control relays via the 1 wire sensor, and via RPIGiposetup there would still be 3 free on the relay board
modifications
gexle avatar image
gexle answered ·
Hello Kevin
Please Help!
Thanks
sarah1331 avatar image
sarah1331 answered ·
install SetupHelper and configure a custom Package.
Package name: VenusOS-TemperatureService
GitHub user: DanielFontes
GitHub Tag: latest
this version is without pi cpu temp
but remember gpiosetup will conflice so you need to edit the sensor to an unused pin i use 20
gexle avatar image gexle commented ·
Hello
Thank you very much
With RpiGiposetup I would like to leave the Gipo 26 like that.
After installing your script, can I change the Gipo to 20 or 4?
I wanted to search for the Github page but I can't find any instructions or anything like that.
gexle avatar image
gexle answered ·
Still question If I can then use this script to switch the remaining relays, I would still have 3 left. Because at the moment I can only switch 2 relays or is that only possible with 2 relays in Venus OS...
Only possible to switch 2 the rest are Manual relays
matteburk avatar image
matteburk answered ·
How do i enable ADC... I can't find any VenusOS-TemperatureService with ADC enabled /Mattias
Experiments, Modifications and Adaptions. Mods (Modifications) can be made to Victron Software by the Community. Please use the modifications space for enthusiasts who want to push what is possible, without official Victron Support.
