I've downloaded a configuration file (.vsc) with VEConfig software from a multiplus 24/3000.
I now would like to check the configuration of Mplus parameters reading the .vsc file ?
How is it possible ?
Thanks for your help
Regards.
Bruno.
Regards.
Bruno.
Very simple in fact...I've just to rightclick on the file and to choose open with VEConfigure to get the configuration.
Another way is to choose "Fake target from file" in the "Port selection Menu".
When running directly VE config, I was disturbed by the "File" Menu which was grayed out making file opening impossible.
Sorry for this useless post ;-)
Regards.
Bruno
VEConfig alternative method for VE.Bus using VictronConnect
45 People are following this question.
