garnet avatar image
garnet asked
Can a Phoenix 12/50 charger parallel both battery charging banks to provide 100amps to a single battery bank?
I have x8 Trojan T-105 wired series/parallel to a single 12volt house bank.
Can I parallel both charging banks of the Phoenix 12/50 charger to a single battery bank to provide 100amps of charge?
Will I loose any functionality? Is there a downside to doing this?
If not, then I am limited to only 50amps of charging.
charger
kai avatar image
kai answered ·
The 12/50 specs says the 50A is shared between outputs 1 and 2. So 50A all up.
garnet avatar image garnet commented ·
Thank you. Somehow I had missed that.
Cheers
Chargers.
