I have two 200w solar panels connected (in parallel) to my MPPT 75/15.
The specs say that nominal input PV is 220w.
What happens if the solar panels produce more than 220w?
The MPPT regulates the power produced by the panels.
It's normal to put panels with a higher max power than the MPPT can output. This compensates for low input due to clouds, rain etc.
As long as the max input voltage of 75V isn't exceeded and you haven't exceeded Isc, you will be ok.
What does “you haven't exceeded Isc” mean?
38 People are following this question.
