The logfile of my Bluesolar MPPT charger shows max. PV voltages that are higher that my panel's Voc spec: 23,4V.
Logged voltages go as high as 23.92V
How's this possible, can it be harmful ?
THANKS,
V.
THANKS,
V.
The VOC is given at a standard temperature, if the panels are below the standard temperature then VOC will be higher. This is normal behaviour and nothing to worry about.
34 People are following this question.
