hi, is it possible to modify bmv-700 values with a cerbo-gx via vrm portal?
Yes it is, if you use victron connect and sign in to the VRM through Victron connect.
thanks! ,and is it possible to modify bmv-700 values with a GlobalLink 520 via vrm portal?
I have never tried that.
I can see why you wouldn't. It allows remote firmware updates.on the device list. If it does then you should be able to I would think anyway.
56 People are following this question.
