I don't see a way to create a preset and specify the maximum amps. Am I missing how I should set this?
Thanks,
Jeff
Thanks,
Jeff
Settings>Advanced Settings>Advanced Battery Settings>User Defined
You can also change your charge current directly from Settings, of course.
I should have added a bit more detail, sorry.
So when I edit presets, I don't see the maximum charge current. I suspect this means the preset will use whatever maximum charge current was previously selected for whichever preset was used just before selecting the preset.
Victron,
Could the ability to set the maximum charge current for a preset be added to an upcoming firmware release?
Jeff
Blue Smart IP22 Product Page
Blue Smart IP22 230v datasheet
Blue Smart IP22 120v datasheet
Blue Smart 120v manual download
Did You Know? - use the blue smart as a power supply (video link)
History and Settings for Blue Smart Chargers in Victron Connect (video link)
39 People are following this question.
