charliep avatar image
charliep asked
Fischer Panda NMEA & CCGX
I have a Fischer Panda 5000i Neo which has the iContol/xControl interface, this has an output for VE.Can. The problem is I have already connected the VE.CAN to my NMEA2000 bus for the Tank Sensor. Connecting the iControl to the NMEA2000 bus does not seem to work, I can see it using the NMEA analysis tools, but the CCGX cannot see it.
Is there any way I can have both NMEA2000 and connect the genset?
Many thanks...
...(c)
Generator
Paul B avatar image
Paul B answered ·
I presume you are wanting gen auto-start here
the Panda also has a 2 wire connection on the rear of its control panel that you just connect straight to the CCGX relay and this will then control the Auto-start.
if thats what you are trying to achieve that is as its not mentioned in your post
charliep avatar image charliep commented ·
I'm trying to get the genset data to appear in the CCGX, it should appear giving data about the genset and a pretty picture (and support autostart) but at the moment it doesn't show at all.
