andrew-mackenzie-bauer avatar image
andrew-mackenzie-bauer asked
Multiplus 2 setting AUX relay SOC with BYD LVL
Hi Team,
I have a Multiplus 2 installed with a Venus GX and BYD LVL 15.4kwh battery. I am using the programmable relay on the venus to start/stop the generator. I would like to use anther relay to control a load once the batteries are full. I have a two additional programmable relay available to me. One on the MPPT charge controller and one AUX on the Multiplus. The problem I have is that neither the charge controller or the Multiplus can see the state of charge once connected to the BYD battery systems. I have successful used these relays on lead acid systems but can seem to get them to see SOC once connected to the BYD Battery.
Multiplus-IIBYD
Alexandra avatar image
Alexandra answered ·
@Andrew MacKenzie-Bauer
You can use the VE bus SOC in the settings.
Since the BYDs reports their SOC to the system through the Venus, it will synchronise with that.
andrew-mackenzie-bauer avatar image andrew-mackenzie-bauer commented ·
Hi Alexandra,
I have just had a look in this Charge Controller and the Multiplus and cannot see any setting to select for VE Bus SOC. Do you need to activate any setting for the Venus to share this or setup any assistance in the Multiplus?
