decp avatar image
decp asked
Smart MPPT 100/20 Changing Battery and voltage
I have a small setup with a Blue Solar Smart MPPT 100/20 on a 12V Lithium Ion 100Ah. I am upgrading to to 24V 100Ah and adding Battery Protect and a BMV712. My question is; do I have to do a factory reset before I connect to the new higher voltage (24V) ? as I do not want to blow the MPPT controller.
Also do I need to clear the history?
MPPT Controllers
wkirby avatar image
wkirby answered ·
It's very easy to change the battery Voltage in the Victronconnect App.
Go to seetings -> Battery and the first option on the list is the battery Voltage selction.
It will not be necessary to clear the history, but you can if you want to. Press the clock button on the main screen:
