How can I buy a compatible Multiplus II for install a split Phase ore 3 Phase System , I have one Multiplus II GX 48/3000/35-32 230V running from 2020 as a one phase system.
PN:PMP482306000
SN:HQ1939XXHLU
hw rev.04
PN:PMP482306000
SN:HQ1939XXHLU
hw rev.04
Yours is from HQ19 so from 2019.
You are not likely to get compatible ones now. Most suppliers would have moved all of that stock long ago.
You would be better off starting with all new units and selling that one unit off.
The important detail is the product ID, you can find that in the device list in the VRM Portal.
That ID must match with all units. You should contact your local Victron dealer.
Thanks for information - I have this device
Is it possible to buy compatible devices - ore need I to make a complete new system (would be a bit expensive in relation to the possible benefit)
94 People are following this question.
