lex2k0 avatar image
lex2k0 asked
Quattro 2 Battery Load Ampere Limit
Hi there,
I was recognizing that the Quattro 2 is disconnecting the generator or landline when it charges with a big amount the batteries and then a high usage of 230V is coming. And then it tries to reconnect later on.
As this could happen often while cooking for example I have a feature request. Would it be possible to also add the ampere charge limit to the victronconnect app like the ampere limit for the landline? So it would be possible that I could reduce the charge limit while I have special cooking usage of others and after that I can increase the battery load limit again. But this way the Quattro 2 would not disconnect the land line so often because it will not exceed more than the allowed ampere from the landline.
It hope that is a good idea to be integrated.
Thanks a lot
feature request
The feature requests topic tag can help Victron R&D find feature suggestions for products.
There are many factors that go into the Victron product roadmap, and feedback from end-users can help.
