Are there any issues with grounding the positive side of the 48v battery system on a Quattro or MTTP controller. I have some telco equipment that requires a positive ground to work.
Cheers
Hi @derek@hitechsolutions.co.nz
I don't think this will be a problem.
Inside the Quattro or MPPT there is no connection between battery negative and the casing.
10 People are following this question.
