laurent avatar image
laurent asked
Connect SmartSolar MPPT to Venus GX via bluetooth
I would like to remote 3 smart solar MPPT charge controler.
Is it possible to connect them to the Venus GX trough bluetooth or the only to do it is to use VE.direct cable ? (meaning I will be able to connect only 2 controler)
regards,
Laurent
Venus GX - VGX
Elimac avatar image
Elimac answered ·
I don't think you can connect MPPT via bluetooth, at least without external adapter. As far as I know Venus GX has builtin Wi-Fi but not bluetooth. What you can do is connect another MPPT via USB using an adapter cable (victron acessory). I have such solution and is working perfectly. You could also add an USB hub if you need more connections, up to a limit (about 5 devices, globally, to be safe)
laurent avatar image laurent commented ·
Thank you you very much !
