skateboardsebi avatar image
skateboardsebi asked
250/100 more panels?
Hello, im new here and i have a simple question. I have a 250/100 to load my 14,4 kW-24v-lifepo-battery. I have 6x435panels (2s3p) which is only 2610w. But the 250/100 could handle about 3000w. Now i have more available space on the roof for 1 more panel. Ist there any way i could connect that one more panel to the system?
And If not, is it possible to connect a 75/15 with the 250/100 without problems. How do they connect with each other?
Thanks for helping
Sebastian
Solar Panel
Alexandra avatar image
Alexandra answered ·
@Skateboardsebi
There is no way to have uneven strings on the 250/100. You would need a separate charge controller.
If they are both programmed the same they will be fine. Do you have a GX? Or a raspberry pi?
skateboardsebi avatar image skateboardsebi commented ·
No, no GX, no raspberry. But do you mean, if i set the same parameters i can just use them parallel? The chargers dont have to be connected?
Alexandra avatar image Alexandra ♦ skateboardsebi commented ·
If they are set to charge to the same voltages they will be fine as individuals.
They will run with their own internal charge cycles.
