I get this fault every time after running generator. Was not like this before. Anyone else getting this?
I have seen that happen on a system where the MP was charging higher than it should have been because DC ripple from a loose connection was causing incorrect voltage readings.
Nothing is loose in this setup. There are other solar chargers and a lot of logging devices. No one reports anything wrong or suspicious voltage, only the 250/60 MPPT. I see the latest firmware (1.61, which also this device has) has some changes regarding voltage detection. I suspect there might be a new bug regarding this function with the new firmware, as the error reports:
Possible reasons for this error to occur:
The Battery voltage (12/24/36/48V) is set incorrectly. Use VictronConnect to set the right Battery Voltage.
But voltage is since installed locked to 48. Other Victron MPPTs in the same setup does not trigger an alarm.
94 People are following this question.
