I cannot solve the following problem without support.
I have installed a Cerbo GX with tank 140 and all tank sensors are activated in the I/O settings. Nevertheless, I do not see the sensors in the device list. What could be the problem?
Argh I just see your post and have exact same problem.
Have you found a solution?
Even more strange, I see that my GX Tank 140 has exactly the same serial number: HQ2233MJAFG !!!
Don't tell me that you have returned your failed device to the vendor, and I'm the "lucky" boy that purchased it after.... :-/
Hey both, that is indeed really strange!
I’ll get it looked into and will get back to you next week.
@mvader (Victron Energy) Thanks for looking at it.
Serial number on the sticker is matching the serial number reported in the GUI.
See below.
@mvader (Victron Energy) did you had a chance to look at it? Should Return it to the vendor as they request me to do so?
I found strange that it show-up in I/O but not in the device lists, despite the inputs are enabled in the I/O menu. Any FW update required?
Thx in advance,
FreD.
45 People are following this question.
