james09 avatar image
james09 asked
MPPT Charge Controller Error 38
Hello, I have an easy solar 24/3000/70-50 with an additional MPPT 150-35. Unfortunately the inbuild MPPT 150-70 has shutdown and is showing error 38. I am unable to access the remote console (something about IP addresses blocked) but the system is online on the VRM and I have access to VEConfig and have already updated all the firmware. The installation is 9 hours away (!!) and we dont have a good victron technician nearby to assist. Is anyone able to help me remotely fix this problem? Thank you!
MPPT Controllerserror 38
Alexandra avatar image
Alexandra answered ·
@James09
If the owner of the system is comfortable, get them to shut down the whole system.
Switch off PV
Switch off inverter
Switch off battery
Wait 3 minutes
Switch on battery
Switch on inverter
Switch on PV
Then you would need to check with Victron connect over the VRM if the mppt has been programmed correctly. As in correct battery voltage etc.
You could try (but this is a long shot) using Victron connect on the VRM tab. (You might have to link them) there is no need for the remote console here. I have recovered an error 38 like this once before.
Reset the mppt to default using VC over the vrm. Update firmware if needed.
Then reprogram.
MPPT Product Page
MPPT Error codes
