jph44 avatar image
jph44 asked
What is the best electric schéma to connect ac circuit with multiplus 2 gx with mppt
hello
I have install to lower my consumption an multiplus 2 GX 3kva linked to batteries 24v 7,2 kWh and solar panels 1200w with mppt 150/70.
i want to used the opportunity to have power wherever the grid is.
So I connect my secure elements on ACout1, and the rest of charges are connected on the ACout 2.
Everything works well except my schéma on VRM console. I don t see protected loads. Is it normal?
the second question is : is my electric connection is ok?
thanks for you help
Multiplus-II
