n1co avatar image
n1co asked
Bidirectional charge/discharge battery, externally controlled
I am looking for a bidirectional inverter that allows me to dynamically charge and discharge my storage. Both operations should be as continuous as possible and controllable from an external source. This should be done through an open interface, either digital or analog.
One AC phase is sufficient for me, and the inverter should deliver approximately 2-3.5 kW of power.
Is it possible to achieve this with the Victron Energy MultiPlus (2)?
Thank you very much.
Multiplus-II
Alexandra avatar image
Alexandra answered ·
@N1co
Yes it is possible with the Multiplus 2 as it is an inverter charger.
Controlled externally by either by modbus or a battery control system or node red. And can be integrated into Home Assistant and a few other things.
Help for these topics can be found in the modifications space or the node red space on this forum. They are not officially supported by Victron.
