s1277 avatar image
s1277 asked
GPS Issue while stationary
Added GPS to cerbo
It is acting weird on My RV which has not moved since I installed it
https://www.google.com/maps/d/edit?mid=1I3HekE_cnE7XMyLwGryA7IJLiiC_bwk&usp=sharing
using GlobalSat ND-105C Micro USB GPS Receiver in middle usb port on cerbo
rv has not moved
Also how do I reset to start stop a trip to download in vrm?
gps
pwfarnell avatar image
pwfarnell answered ·
My GPS location also bounces around a bit, always thought it was because it is inside a steel boat reducing satellite signal strength. If you use a geofence alarm you need to set the boundary a few hundred meters larger than required.
If you only want to download a specific set of times from VRM, then have the GPS widget in the Advanced page and at the top of the Advanced page select a custom time range. Then download the KML file and it will only have the required date range. This is how I do mine.
