nairbbrian avatar image
nairbbrian asked
Bluesmart ip22 3 output charger connected to 2 separate solar setups .Common Negative?
Does anyone see a problem with this setup . 4x 100ah and 2x 100ah batteries all victron excepr the Renogy panels x .there doesn,t seem to be any conflict with the solar controllers which are set to 14.4 volts and the chargers lipepo default is 14.2 a little lower than the solar charger.
Thanks for any advice friends.
bluesmart ip22
Mike Dorsett avatar image
Mike Dorsett answered ·
No problems, just note the preferred method of connecting batteries in parallel: the positive and negative load/charge connections are at opposite ends of the string, so total interconnect resistance is the same for all batteries.
