After installing a second multiplus 2 in parallel on my system, I encountered some problems. First, by connecting the two inverters via VE bus directly to Cerbo GX, the system goes into error. I therefore had to connect it via the MK3 to USB interface. Very strange, the inverters are working and powering the house and the exteriors but the Remote Console tells me that the inverter is off. Same thing on the VRM portal.
