demderder avatar image
demderder asked
what do i need to do to swap my raspberry pi?
i want to swap my raspberry pi as i have an 8gb version running venus and i want to swap to mt 4gb version.
do i just swap the memory card to the new pi and plug everything back in?
will i have connection issues to my vrm portal?
i want to get it right as i rely on vrm portal
Raspberry Pi
Alexandra avatar image
Alexandra answered ·
@demderder
The Pi itself gives the identifier so you would need to move the install the same way you would if you were upgrading/changing your GX if you want to migrate the data as well.
Other wise you just register the 'new GX' with the memory card.
You should be able to use the option to replace a GX VRM - Settings - General...
demderder avatar image demderder commented ·
Thank you, this worked perfectly.
