philfine avatar image
philfine asked
How to keep critical loads on when shutting down Multiplus-II
Hi everyone,
If for some reason I need to shutdown the Multiplus-II, all of the critical loads would be disconnected.
Is there a way to avoid this to happen.
For reference this is a residential instalation with reliable Grid. Would like to find a solutions not to disconnect the server room when I need to do maintenance of the batteries.
Regards
Multiplus-II
nickdb avatar image
nickdb answered ·
You could hang a ups off the back of the inverter.
Otherwise it is a changeover switch, not sure if ones exist that can switch fast enough without dropping power.
I have a mini ecoflow system that is behind the multis running my switching, routing and AP’s for this purpose.
