ahforster avatar image
ahforster asked
What charger for 125Ah SuperCycle
My AGM 125Ah Supercycle battery in our Mobilehome is charged by a built-in electroblock (Schaudt EBL99) with a maximum of 14.3 Volts. The battery does not exceed 14.26V (Visible on the smart shunt).
There are also 2 solar panels (Victron together 280 Wp) with an MPPT 100/20 charger. The panels and charger were installed today, but due to the lack of sun I cannot yet see whether they fully charge the battery.
I read on a forum that it is also better to charge the battery a few times a year with an external charger. One that can supply 14.8 volts. So if I let the charger do its work "next to" the electroblock charger, it will fill the gap between 14.3 and 14.8 Volts.
But I am confused regarding the different types (IP22 / IP65 / IP67) and the different Amps I can choose. I don't want the"highest" solution but one that could do the job right.
What would an expert advise me on this?
charger
kevgermany avatar image
kevgermany answered ·
The IP numbers refer to water and ingress protection.
Your solar charger will fully charge the battery if you don't use more power in a day than solar can provide.
Charging to 28V should only be done if recommended by the battery manufacturer/supplier for that type of battery. Most batteries do not need it and can be damaged by it. The solar charger has a setting for it, suggest you disable it. In Victron terminology it's called equalisation.
Charge current. If there are no instructions from the battery supplier, a good max is one fifth of the capacity. So up to 20A for a one hundred amp hour battery. Err lower if needed, just takes longer.
ahforster answered ·
I assume your 28V is 14,8V? In the specs of my 125 Victron Supercycle it states that a charge of 14,6-14,9 fast recharge is possible.
Yes, I mixed up the systems, sorry.
The fast charge settings are ok if it's in the instructions, but can shorten battery life.
Chargers.
