volker-lorenz avatar image
volker-lorenz asked
X-axis Timeline isn't showing for all widgets on mouse over
Hi! In the past, the vertical line on x-axis (time)of all widgets were synchronous. Now, only the widget with "mouse over" shows that line. is it adjustable? thanks, Volker
widget vrm
Hi @Volker Lorenz,
I couldn't reproduce the issue and all are still showing as synchronised for me.
Could you try on a different computer (running a different browser) and see if you still have the same issue?
If you do, could you try removing all your widgets except for 2 and see if you still have the same issue?cleanshot-2023-10-11-at-180047.jpg
volker-lorenz answered ·
Its not depending on the browser, all devices incl. mobile phone show the same.
Is it possible to save the widget config before? thx
Hi! I removed one widget and the problem was fixed. All timelines were there again. After that i reactivated that widget and all was fine. Thanks!
( i made screenshots before, to get the familiar arrangement)
Thanks for reporting back, and good to hear the work around worked.
In Chrome, the Hyperlink to switch a widget on / of direkt in the upper list with a hook don`t work.
In IE and firefox it works. The (not)synchronous timeline problem happened again, it always helps to switch of and on one widget.
