Venus v3.10 allows to set Self Consumption from Battery to All system Loads or Only critical loads.
Can I use this feature from Node-Red too? I couldn't find it in the ESS node. Please Help!
Hello, I am new here. My setup has been powered on few days ago...
+1 for this topic, I having the exact same need with EV charger in manual mode (mostly at night) and should not be powered by 48V battery. I would like to be able to disable automatically the self consuption mode when EV starts charging the car.
Hope it will come soon!
Hello everyone,
I have tried something: Did only two trial, but it seems to be working (at least if EV power measurement is not too wrong // EV conversion factor topic...)
Basically, I take EV power measurement and report it to the grid setpoint so DC battery of the victron system is not drained to the EV. Update rate @30sec, looks enough to me.
Conditions (can be tweaked in the "EV auto grid setpoint" function) :
- works in schedule or manual mode (not in auto mode then).
- Default grid setpoint is 0W
- if DC battery SOC is > 90%, use grid + 3200W of solar energy (random number, didn't search for available solar energy measure info if any...)
- if DC battery SOC < 90% , use grid only
- if using solar energy and SOC drops down < 90%, move to full grid and wait for SOC > 92% to come back to mix grid + solar
Note 1 : tested with multiplusII in ESS mode.
Note 2 : It's my first Node-Red script, please be nice :)
[{"id":"082636088106943c","type":"tab","label":"EV auto grid setpoint","disabled":false,"info":"auto adjust grid setpoint on EV chagrer consuption to avoid using 48V battery power\n\n- only if EV is charging\n- in schedule or manual mode\n- SOC < 90% grid setpoint = charge power\n- SOC >=92 grid setpoint = charge power - 3200w (multi to provide this power)\n- default setpoint is 0W\n\n","env":[]},{"id":"0c40551a298e7b37","type":"victron-input-battery","z":"082636088106943c","service":"com.victronenergy.battery/512","path":"/Soc","serviceObj":{"service":"com.victronenergy.battery/512","name":"Batteries"},"pathObj":{"path":"/Soc","type":"float","name":"State of charge (%)"},"name":"","onlyChanges":true,"roundValues":"no","x":200,"y":60,"wires":[["26b7de59304870d0"]]},{"id":"bc9bc8a30bf465f9","type":"victron-input-evcharger","z":"082636088106943c","service":"com.victronenergy.evcharger/40","path":"/Status","serviceObj":{"service":"com.victronenergy.evcharger/40","name":"EVCS-HQ2245RMAVN"},"pathObj":{"path":"/Status","type":"enum","name":"Status","enum":{"0":"Disconnected","1":"Connected","2":"Charging","3":"Charged","4":"Waiting for sun","5":"Waiting for RFID","6":"Waiting for start","7":"Low SOC","8":"Ground fault","9":"Welded contacts","10":"CP Input shorted","11":"Residual current detected","12":"Under voltage detected","13":"Overvoltage detected","14":"Overheating detected"}},"initial":"","name":"","onlyChanges":true,"x":210,"y":180,"wires":[["4b7784eab6466e66"]]},{"id":"986d024954276190","type":"victron-output-ess","z":"082636088106943c","service":"com.victronenergy.settings","path":"/Settings/CGwacs/AcPowerSetPoint","serviceObj":{"service":"com.victronenergy.settings","name":"Venus settings"},"pathObj":{"path":"/Settings/CGwacs/AcPowerSetPoint","type":"integer","name":"Grid set-point (W)","writable":true},"name":"","onlyChanges":false,"x":1160,"y":280,"wires":[]},{"id":"26b7de59304870d0","type":"function","z":"082636088106943c","name":"global SOC","func":"\nglobal.set(\"SOC\",msg.payload);","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":60,"wires":[[]]},{"id":"4b7784eab6466e66","type":"function","z":"082636088106943c","name":"Global evcsstatus","func":"global.set(\"evcsstatus\",msg.payload);\n\n// if not charging\nif(msg.payload != 2)\n{\n //push 0W grid setpoint\n msg.payload = 0;\n return msg;\n}","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":570,"y":180,"wires":[["986d024954276190","5a1f47f8bb1f89dd"]]},{"id":"544e97e0f864a164","type":"inject","z":"082636088106943c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"30","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":380,"wires":[["7c7f21401ac1472d"]]},{"id":"7c7f21401ac1472d","type":"function","z":"082636088106943c","name":"EV auto grid setpoint","func":"var EVmode = global.get(\"evcsmode\");\nvar EVstatus = global.get(\"evcsstatus\");\nvar BATTsoc = global.get(\"SOC\");\nvar EVchargepower = global.get(\"evcspower\");\nvar ALARMlowsoc = 0;\n\n// if charging state\nif(EVstatus == 2)\n{\n //if manual or schedule mode\n if(EVmode == 0 || EVmode == 2)\n {\n //if SOC\n if(BATTsoc < 90 || (ALARMlowsoc == 1 && BATTsoc < 92))\n {\n ALARMlowsoc = 1;\n //do not use 48V battery nor sun\n msg.payload = EVchargepower;\n }\n else //soc > 90 or > 92 if limit reached once\n {\n ALARMlowsoc = 0;\n // Limit to 3200W output from multi (12A)\n EVchargepower = EVchargepower - 3200;\n \n //avoid injection\n if (EVchargepower > 0)\n { \n //limit multi to 3200w\n msg.payload = EVchargepower;\n }\n else\n {\n // full multi, but avoid injection\n msg.payload = 0;\n }\n\n }\n }\n else\n {\n msg.payload = 0;\n }\n//send new grid setpoint\nreturn msg;\n}\nelse\n{\n //not charging grid setpoint back to 0\n //default 0 value send by status change\n}\n\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":580,"y":380,"wires":[["986d024954276190","95de6814fc7b7849"]]},{"id":"6e47c1f157feadc8","type":"victron-input-evcharger","z":"082636088106943c","service":"com.victronenergy.evcharger/40","path":"/Ac/Power","serviceObj":{"service":"com.victronenergy.evcharger/40","name":"EVCS-HQ2245RMAVN"},"pathObj":{"path":"/Ac/Power","type":"float","name":"Total power (W)"},"name":"","onlyChanges":false,"roundValues":"no","x":240,"y":240,"wires":[["2e1548e4c1ac6bca"]]},{"id":"2e1548e4c1ac6bca","type":"function","z":"082636088106943c","name":"Global evcspower","func":"global.set(\"evcspower\",msg.payload);","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":570,"y":240,"wires":[[]]},{"id":"95de6814fc7b7849","type":"debug","z":"082636088106943c","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1080,"y":380,"wires":[]},{"id":"5a1f47f8bb1f89dd","type":"debug","z":"082636088106943c","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1080,"y":180,"wires":[]},{"id":"17a7457480ae6992","type":"victron-input-ess","z":"082636088106943c","service":"com.victronenergy.settings","path":"/Settings/CGwacs/AcPowerSetPoint","serviceObj":{"service":"com.victronenergy.settings","name":"Venus settings"},"pathObj":{"path":"/Settings/CGwacs/AcPowerSetPoint","type":"integer","name":"Grid set-point (W)"},"name":"","onlyChanges":true,"x":220,"y":460,"wires":[["95de6814fc7b7849"]]},{"id":"e41592e2695970f9","type":"victron-input-evcharger","z":"082636088106943c","service":"com.victronenergy.evcharger/40","path":"/Mode","serviceObj":{"service":"com.victronenergy.evcharger/40","name":"EVCS-HQ2245RMAVN"},"pathObj":{"path":"/Mode","type":"enum","name":"Mode","enum":{"0":"Manual","1":"Auto","2":"Schedule"}},"initial":"","name":"","onlyChanges":true,"x":210,"y":120,"wires":[["0697d5b1e6be98db"]]},{"id":"0697d5b1e6be98db","type":"function","z":"082636088106943c","name":"global evcsmode","func":"global.set(\"evcsmode\",msg.payload);","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":120,"wires":[[]]}]
43 People are following this question.
