werner567 avatar image
werner567 asked
VRM API - Overall Stats Bug or Intended?
Hi All,
I've been trying to get accurate consumption data from the VRM portal using the https://vrmapi.victronenergy.com/v2/installations/<site-id>/overallstats query.
However if I look at stats for "Today",
The API returns
 "today": {
            "totals": {
                "bs": 2411.940723632184,
                "bv": 1341.206989048789,
                "total_solar_yield": 0,
                "total_consumption": 8.829152643680573,
                "total_genset": 0,
                "grid_history_to": 0,
                "grid_history_from": 10.977277040481567,
                "Pdc": false,
                "iOI1": false
            "percentages": {
                "bs": 64,
                "bv": 36,
                "total_consumption": 0,
                "total_genset": 0,
                "grid_history_from": 0,
                "Pdc": 0,
                "iOI1": 0
VRM portal states a lower usage than the API
  • From Grid: 2.6kWh
  • Consumption: 2.4kWh
Now what I found, is that if I select VRM Portal data of the "Last 24 Hours" it seems to match the API call
  • From Grid: 11kWh
  • Consumption: 8.8kWh
I've tried doing the same for Month, but I could find any link just yet.
Question?
1. Is this intended to work like this, or is this a timezone issue or possibly a bug?
This makes it very difficult to actually accurately track consumption in the system.
It would be greatly appreciated if assistance on this can be provided.
Thanks in advance
apiportal
