my ev has 24s with 180ah. nominal voltage is up to 24x3,6 i.e. 86,4V. Can i use the smartshunt 500a for this voltage, as it is once said to max with 50v and at another point with 100v. thank you for clearance before i connect that high voltage
The normal SmartShunt is only for max. 70V:
https://www.victronenergy.com/upload/documents/Datasheet-SmartShunt-EN.pdf
There is a high voltage model for 60-385Vdc:
https://www.victronenergy.com/battery-monitors/bmv-700h
39 People are following this question.
