wgh52 avatar image
wgh52 asked
MK3 or bluetooth dongle cannot see/connect to Mulitplus II
New install. Yesterday, I was able to see multiplus II with the bluetooth dongle. It got late so I turned off the unit to pick up today. This AM, mk3 was seen in victron connect but could not connect to Multiplus II. I moved the cat6 cable from the mk3 and inserted into Bluetooth Dongle. Connect via VictronConnect, the only thing showing was the battery temperature and battery voltage. I purchased a Cat5e cable because I read where this corrected a simple problem. No luck. I have verified that the correct driver is installed. Any suggestions appreciated otherwise I will need to deinstall and return.
Multiplus-II
Is the inverter switched on?
wgh52 avatar image wgh52 Alexandra ♦ commented ·
Yes
wgh52 avatar image
wgh52 answered ·
On other bit of information. Yesterday, when I was able to see the multiplus II with using the Bluetooth Dongle the unit status was Initialise. Over a half hour never changed.
